Phillips Jupiter
It's a Dutch company actually, even though it may have been made for the German or Austrian market. In my experience Phillips sets are better designed and better made then the typical German brands. It's likely that the only parts that will need replacement will be the electrolytics, and maybe some tubes, I don't see any of the black types made out of molded tar under that chassis .
Phillips Jupiter - by w4rtc - 02-01-2014, 09:55 PM
RE: Phillips Jupiter - by Arran - 02-01-2014, 11:45 PM
RE: Phillips Jupiter - by morzh - 02-02-2014, 12:39 AM
RE: Phillips Jupiter - by Paul Philco322 - 02-02-2014, 10:22 AM
RE: Phillips Jupiter - by w4rtc - 02-02-2014, 01:40 PM
RE: Phillips Jupiter - by gregb - 02-02-2014, 03:08 PM
RE: Phillips Jupiter - by Arran - 02-03-2014, 01:35 AM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
