Anyone has heard of this Philco-Tropic Radio 41-714 before?
I'd like to see pictures of that chassis outside of the radio also.
I suspected something was done to the chassis because of the strange knob layout.
There are currently 8708 online users. [Complete List]
» 3 Member(s) | 8705 Guest(s)
