Philco model 70 rebuild - by Tim P.
Threads: 562
One more thing:
Your electrolytics look like the one I had in my 90, probably an original, with this thick aluminum rod and backelite insulator.
In case you have trouble extracting that rod and/or broken insulator, in my 90 topic I had rebuild described for that cap, could be useful for you - I used a Home depot / Lowes part for the insulator which works quite nicely in the setup.
RE: Philco model 70 rebuild - by Tim P. - by morzh - 02-03-2014, 12:38 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 4305 online users. [Complete List] » 1 Member(s) | 4304 Guest(s)
