Worth going to look at?
Worth? Absolutely.
$100? If you really want it, otherwise personally I would haggle it down.
Worth going to look at? - by LASJayhawk - 02-03-2014, 12:49 PM
RE: Worth going to look at? - by morzh - 02-03-2014, 12:54 PM
RE: Worth going to look at? - by OldRestorer - 02-03-2014, 01:03 PM
RE: Worth going to look at? - by Eliot Ness - 02-03-2014, 01:41 PM
RE: Worth going to look at? - by TA Forbes - 02-03-2014, 04:38 PM
RE: Worth going to look at? - by Jayce - 02-03-2014, 11:35 PM
RE: Worth going to look at? - by PhilcoJohn - 02-04-2014, 03:42 PM
Philco 91 Tuning Condenser
