electrolytic's
Always OK to replace with a higher D.C. rating and mind carefully the polarity. Modern components wqill be a fraction of the old parts, but do follow the original dressing of leads. Do make sure original parts are disconnected or totally (best) removed from the set.
electrolytic's - by Nickster - 02-03-2014, 02:18 PM
RE: electrolytic's - by morzh - 02-03-2014, 02:26 PM
RE: electrolytic's - by codefox1 - 02-03-2014, 02:28 PM
RE: electrolytic's - by Nickster - 02-03-2014, 06:04 PM
RE: electrolytic's - by hsusmann - 02-03-2014, 06:15 PM
RE: electrolytic's - by skyscraper - 02-03-2014, 06:42 PM
RE: electrolytic's - by Nickster - 02-03-2014, 06:48 PM
RE: electrolytic's - by morzh - 02-03-2014, 08:37 PM
Philco 91 Tuning Condenser
There are currently 7547 online users. [Complete List]
» 2 Member(s) | 7545 Guest(s)
