38-12 Volume control that will not stop audio
Have you simply measured your volume pot and made sure it is what it says and that the wiper connects to the lower pin when the volume is all the way down (should be within 50 Ohm or so).
How loud is it when turned down?
Simple test - short the wiper and the lower pin, and see if this brings the volume down the way it is expected.
RE: 38-12 Volume control that will not stop audio - by morzh - 02-03-2014, 03:43 PM
Philco 91 Tuning Condenser
