Philco 620B alignment woes
Bill, antenna connection are you using? The post on top of the chassis, or the screws on the back of the chassis?
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Philco 620B alignment woes - by wonderwrench - 06-19-2008, 06:29 PM
[No subject] - by wonderwrench - 06-20-2008, 07:02 PM
[No subject] - by BDM - 06-20-2008, 07:19 PM
[No subject] - by wonderwrench - 06-20-2008, 07:46 PM
[No subject] - by BDM - 06-20-2008, 07:58 PM
[No subject] - by wonderwrench - 06-20-2008, 08:03 PM
[No subject] - by wonderwrench - 06-21-2008, 11:52 AM
[No subject] - by BDM - 06-21-2008, 12:24 PM
[No subject] - by wonderwrench - 06-21-2008, 12:51 PM
[No subject] - by BDM - 06-21-2008, 01:16 PM
[No subject] - by rghines1 - 06-21-2008, 01:33 PM
[No subject] - by BDM - 06-21-2008, 11:56 PM
[No subject] - by wonderwrench - 06-23-2008, 03:26 PM
[No subject] - by wonderwrench - 06-23-2008, 04:03 PM
[No subject] - by etech - 06-23-2008, 06:33 PM
[No subject] - by wonderwrench - 06-29-2008, 06:23 PM
[No subject] - by wonderwrench - 07-06-2008, 12:26 PM
[No subject] - by Ron Ramirez - 07-06-2008, 02:46 PM
