Anyone has heard of this Philco-Tropic Radio 41-714 before?
Yes indeed, check out the picture I posted earlier and compare it to this one (http://www.radioatticarchives.com/radio.htm?radio=8560), as you see whoever did this added a layer on the bottom part of the facade of 'my' radio in order to hide the holes where the knobs were previously located, and did a couple of new holes to 'relocate' the knobs...
Philco 91 Tuning Condenser
There are currently 10014 online users. [Complete List]
» 2 Member(s) | 10012 Guest(s)
