Philco 620B alignment woes
If I remember right, the 75 has had issues like that. Hopefully someone else will comment on that tube further. Are you sure you have the local oscillator adjusted high, and now low of the carrier freq? Do the antenna trimmers peak?
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Philco 620B alignment woes - by wonderwrench - 06-19-2008, 06:29 PM
[No subject] - by wonderwrench - 06-20-2008, 07:02 PM
[No subject] - by BDM - 06-20-2008, 07:19 PM
[No subject] - by wonderwrench - 06-20-2008, 07:46 PM
[No subject] - by BDM - 06-20-2008, 07:58 PM
[No subject] - by wonderwrench - 06-20-2008, 08:03 PM
[No subject] - by wonderwrench - 06-21-2008, 11:52 AM
[No subject] - by BDM - 06-21-2008, 12:24 PM
[No subject] - by wonderwrench - 06-21-2008, 12:51 PM
[No subject] - by BDM - 06-21-2008, 01:16 PM
[No subject] - by rghines1 - 06-21-2008, 01:33 PM
[No subject] - by BDM - 06-21-2008, 11:56 PM
[No subject] - by wonderwrench - 06-23-2008, 03:26 PM
[No subject] - by wonderwrench - 06-23-2008, 04:03 PM
[No subject] - by etech - 06-23-2008, 06:33 PM
[No subject] - by wonderwrench - 06-29-2008, 06:23 PM
[No subject] - by wonderwrench - 07-06-2008, 12:26 PM
[No subject] - by Ron Ramirez - 07-06-2008, 02:46 PM
There are currently 10519 online users. [Complete List]
» 3 Member(s) | 10516 Guest(s)
