New and already smoking(literally)
Have you tested the tubes?
Look at the one I mentioned, the very first one.
Check it for shorts.
RE: New and already smoking(literally) - by morzh - 02-03-2014, 03:29 PM
RE: New and already smoking(literally) - by morzh - 02-03-2014, 03:38 PM
RE: New and already smoking(literally) - by morzh - 02-03-2014, 08:34 PM
RE: New and already smoking(literally) - by morzh - 02-03-2014, 09:14 PM
RE: New and already smoking(literally) - by morzh - 02-04-2014, 10:35 AM
RE: New and already smoking(literally) - by morzh - 02-04-2014, 11:28 AM
RE: New and already smoking(literally) - by morzh - 02-04-2014, 11:18 PM
RE: New and already smoking(literally) - by morzh - 02-05-2014, 11:50 AM
RE: New and already smoking(literally) - by morzh - 02-05-2014, 11:51 AM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 10:35 AM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 10:51 AM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 11:24 AM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 12:18 PM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 05:55 PM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 06:54 PM
RE: New and already smoking(literally) - by gregb - 02-06-2014, 07:12 PM
RE: New and already smoking(literally) - by morzh - 02-07-2014, 03:50 PM
RE: New and already smoking(literally) - by morzh - 02-09-2014, 11:23 PM
Philco 91 Tuning Condenser
