Aligning 40-155...signal bleeding in
Is your strong station still all over the dial?
I wasn't sure whether you were hearing a signal from a strong station while you were aligning the RF or after the IF was finished and the signal generator was disconnected. It did cross my mind if it happened while you were aligning the RF presumably without an antenna attached, maybe the signal was coming in from the signal generator.
Glad the new tubes helped.
John Honeycutt
RE: Aligning 40-155...signal bleeding in - by Raleigh - 02-03-2014, 11:38 PM
