38-12 Volume control that will not stop audio
Thanks Gregb, I will have to look around for a better quality pot, if they exsist.
And thanks to all who offered comments.
Regards,
Bill
RE: 38-12 Volume control that will not stop audio - by Flint Hill Bill - 02-04-2014, 08:06 AM
Philco 91 Tuning Condenser
