Threads: 10
City: Columbia, SC
What temperature does a chassis reach under normal operation? I wouldn't think anywhere near 180˚. It's also insulated in a bakelite block, and away from the power resistors.
I'm not trying to cut corners, but at some point I need to stop spending so much money on one set
One last try. Is there any way to figure out/anyone to ask about the winding? I'd really rather not have to swap connections later, it isn't easy to get to.
RE: Model 89 Cathedral - by skyscraper - 02-04-2014, 08:28 PM
Users browsing this thread: 45 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
