Restoration options
exray Wrote:
auplater Wrote:, as I'd like to keep it as original as possible.
With a linseed oil finish?
I think you've mis-construed my approach. I wanted to get back to as close to the original look without stripping and re-lacquering. Using the approach I took restored the areas of lacquer damage and left the good lacquer areas (most of the cabinet) alone. I was able to match the damaged areas with the toned linseed oil approach. If I decide to strip and re-lacquer in the future, that is an still option, but it looks too good now that I'm unlikely to do that.
BTW, I don't consider re-lacquering with present day finishes any more "original" than the approach I've taken, since the original lacquer formula is most likely lost to antiquity.
John L.
Restoration options - by auplater - 06-18-2008, 09:35 PM
Re: Restoration options - by Ron Ramirez - 06-18-2008, 10:05 PM
[No subject] - by 49Stude63 - 06-18-2008, 11:01 PM
[No subject] - by philcobenz - 06-19-2008, 12:32 AM
Options - by auplater - 06-19-2008, 07:08 AM
[No subject] - by philcobenz - 06-19-2008, 11:36 AM
Refinishing - by auplater - 06-19-2008, 02:16 PM
Re: Options - by exray - 06-19-2008, 02:24 PM
[No subject] - by philcobenz - 06-19-2008, 03:37 PM
[No subject] - by 49Stude63 - 06-19-2008, 04:44 PM
Re: Options - by auplater - 06-21-2008, 04:49 PM
Fabric cleaned and reinstalled - by auplater - 06-21-2008, 06:38 PM
[No subject] - by Ron Ramirez - 06-21-2008, 09:53 PM
Tube Shields - by auplater - 06-23-2008, 07:35 PM
[No subject] - by philcobenz - 06-24-2008, 07:05 PM
[No subject] - by auplater - 06-24-2008, 07:44 PM
[No subject] - by Texasrocker - 06-25-2008, 02:48 AM
[No subject] - by auplater - 06-25-2008, 08:38 AM
[No subject] - by Texasrocker - 06-27-2008, 02:18 AM
Plating - by auplater - 07-01-2008, 08:29 AM
[No subject] - by Texasrocker - 07-02-2008, 01:15 AM
Restoration progress - by auplater - 07-02-2008, 08:51 AM
progress made - by auplater - 07-06-2008, 03:08 PM
Re: Restoration progress - by Ron Ramirez - 07-06-2008, 04:50 PM
