Philco 39-45... help?
A 1A slow blow should notr necessarily blow on inrush, especially considering the inrush in tube radios with tube rectifier is not capacitive.
THe output transformer change is quick and nearly painless: just pick one, especially considering a nearly universal rabge offered by Hammond in their 125 series, and they even often fit mechanically.
Philco 39-45... help? - by Dbwaibel - 01-29-2014, 03:02 PM
RE: Philco 39-45... help? - by tab10672 - 01-29-2014, 07:21 PM
RE: Philco 39-45... help? - by morzh - 01-29-2014, 08:59 PM
RE: Philco 39-45... help? - by Eric T - 01-29-2014, 09:06 PM
RE: Philco 39-45... help? - by BrendaAnnD - 01-29-2014, 09:10 PM
RE: Philco 39-45... help? - by Raleigh - 01-29-2014, 09:22 PM
RE: Philco 39-45... help? - by Raleigh - 01-29-2014, 09:35 PM
RE: Philco 39-45... help? - by Dbwaibel - 01-30-2014, 12:24 AM
RE: Philco 39-45... help? - by BrendaAnnD - 01-30-2014, 03:01 AM
RE: Philco 39-45... help? - by hsusmann - 01-30-2014, 09:26 AM
RE: Philco 39-45... help? - by Dbwaibel - 02-03-2014, 11:28 PM
RE: Philco 39-45... help? - by Raleigh - 02-04-2014, 12:05 AM
RE: Philco 39-45... help? - by Dbwaibel - 02-04-2014, 12:11 AM
RE: Philco 39-45... help? - by Dbwaibel - 02-04-2014, 12:31 AM
RE: Philco 39-45... help? - by skyscraper - 02-04-2014, 01:02 AM
RE: Philco 39-45... help? - by Dbwaibel - 02-04-2014, 08:43 PM
RE: Philco 39-45... help? - by morzh - 02-04-2014, 11:21 PM
Philco 91 Tuning Condenser
There are currently 10017 online users. [Complete List]
» 1 Member(s) | 10016 Guest(s)
