A Philco 70/90 5-pin tube socket
Anyone could spare or sell me one?
I bought a new one (porcelain) on eBay, not expensive, nothing to be sad about, but - it is symmetrical when it comes to screwholes and the Philco are off-center.
Or maybe someone knows where to buy - I have not found anything when I looked at the usual suspects. Could be I did not use the search engine well.
I will also put an ad in WTB section, in case someone has it for sale.
Mike.
A Philco 70/90 5-pin tube socket - by morzh - 02-05-2014, 12:58 PM
RE: A Philco 70/90 5-pin tube socket - by morzh - 02-05-2014, 10:19 PM
RE: A Philco 70/90 5-pin tube socket - by TV MAN - 02-06-2014, 10:43 AM
RE: A Philco 70/90 5-pin tube socket - by morzh - 02-06-2014, 10:47 AM
RE: A Philco 70/90 5-pin tube socket - by morzh - 02-06-2014, 11:07 AM
RE: A Philco 70/90 5-pin tube socket - by morzh - 02-06-2014, 03:36 PM
Philco 91 Tuning Condenser
