38-12 Volume control that will not stop audio
The new pot should be an audio taper pot not linear. A linear pot may have too much resistance at minimum setting.
However if it is a linear taper pot, you can try adding a 50K-100K ohm resistor between the wiper and low side of the pot. This will have the effect of unlinearizing the volume control similar to an audio taper pot. The down side is you will lose a bit of volume at the max end.
RE: 38-12 Volume control that will not stop audio - by tom.seeger - 02-05-2014, 01:11 PM
Philco 91 Tuning Condenser
There are currently 8504 online users. [Complete List]
» 2 Member(s) | 8502 Guest(s)
