skyscraper Wrote:There is a bit of a mistake on the schematic that messed me up. It's nearly impossible to explain, but looking at the schematic: http://www.philcoradio.com/tech/images/89v3.jpg
Coming off the screen of the first 44, part 8 and 8A are wired in parallel to ground.
The error is that you misread the schematic. ( 8 ) and (8A) connect to the plate ( not the screen grid) of the 44 RF tube through the primary of RF coil (6).
RE: Model 89 Cathedral - by Ron Ramirez - 02-05-2014, 01:20 PM
Users browsing this thread: 37 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10537 online users. [Complete List] » 3 Member(s) | 10534 Guest(s)
