Threads: 10
City: Columbia, SC
I apologize, I misspoke about the connection. Nevertheless, I think what I said is still true. There are still three part 8s, which doesn't make sense. The condenser list also shows the wrong two together, the .05 and the .0007 should be together, not the .09 and .0007 as printed. The .09 should be a different part number.
From the list of bakelite blocks http://www.philcorepairbench.com/bblokcap.htm I can't find anything that matches a .09 and .0007. It isn't a huge deal, but it does cause you to wire it wrong. Not electrically wrong, but the wrong caps in those two blocks.
I don't think I'm missing anything, am I?
RE: Model 89 Cathedral - by skyscraper - 02-05-2014, 01:40 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 4913 online users. [Complete List] » 3 Member(s) | 4910 Guest(s)
