  • 1 Vote(s) - 5 Average
Philco 45 Butterfly Restoration Chronicles....Finished
#39
Ridiculous!
Not one Philco decal on hand, UGH, Gonna have to wait to finish this restoration. Not liking the gloss so I am going to sand it down and use satin.
RE: Philco 45 Butterfly Restoration Chronicles.... - by OldRestorer - 02-05-2014, 04:55 PM
Philco 91 Tuning Condenser
