Have I lost my mind?
Oh, I would pick a 41-280 over a 42-380. Both are a pain to service, owing to all those rubber-covered wires, and the 41-280 is especially fun with lots of wires crowded around that little band switch.
But just let anything go wrong with that pushbutton band switching arrangement on the 42-380, and you're in for some REAL fun. Icon_evil
Oh yes, I once had to replace the entire pushbutton assembly on a 42-380 to get it to work. Was that ever a job! Not one I would want to repeat anytime soon. Ranks right up there with moisture in the oscillator coils in Philco 89 sets.
As for 41-280 donors, Model 41-250 has a nearly identical chassis. Models 41-255, 41-285, 41-287 and 41-290 are similar save for an additional tube or two.
Have I lost my mind? - by Bill Hutchinson - 10-05-2005, 08:45 PM
[No subject] - by PTurney - 10-05-2005, 09:06 PM
[No subject] - by Bill Hutchinson - 10-05-2005, 09:40 PM
[No subject] - by PTurney - 10-05-2005, 09:47 PM
Dial pointer - by 49Stude63 - 10-06-2005, 09:49 PM
[No subject] - by Ron Ramirez - 10-06-2005, 10:19 PM
Re: Dial pointer - by PTurney - 10-06-2005, 11:10 PM
[No subject] - by 49Stude63 - 10-07-2005, 01:22 PM
[No subject] - by Bill Hutchinson - 10-07-2005, 03:34 PM
