New and already smoking(literally)
#40
That's what he is saying, that ANYTHING less than an open means that there is leakage between the heater and the cathode.
Hickok testers usually allow for > 200K ohms leakage between tube elements, but in the case of H to K leakage my personal opinion is that any leakage can be problematic.
RE: New and already smoking(literally) - by morzh - 02-03-2014, 03:29 PM
RE: New and already smoking(literally) - by morzh - 02-03-2014, 03:38 PM
RE: New and already smoking(literally) - by morzh - 02-03-2014, 08:34 PM
RE: New and already smoking(literally) - by morzh - 02-03-2014, 09:14 PM
RE: New and already smoking(literally) - by morzh - 02-04-2014, 10:35 AM
RE: New and already smoking(literally) - by morzh - 02-04-2014, 11:28 AM
RE: New and already smoking(literally) - by morzh - 02-04-2014, 11:18 PM
RE: New and already smoking(literally) - by morzh - 02-05-2014, 11:50 AM
RE: New and already smoking(literally) - by morzh - 02-05-2014, 11:51 AM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 10:35 AM
RE: New and already smoking(literally) - by TA Forbes - 02-06-2014, 10:47 AM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 10:51 AM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 11:24 AM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 12:18 PM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 05:55 PM
RE: New and already smoking(literally) - by morzh - 02-06-2014, 06:54 PM
RE: New and already smoking(literally) - by gregb - 02-06-2014, 07:12 PM
RE: New and already smoking(literally) - by morzh - 02-07-2014, 03:50 PM
RE: New and already smoking(literally) - by morzh - 02-09-2014, 11:23 PM
Philco 91 Tuning Condenser
There are currently 4735 online users. [Complete List]
» 2 Member(s) | 4733 Guest(s)
