1st radio ever, Philco 37-640 restoration (DONE)
Arbeit macht das Rundfunk süß......und der Rücken weh.
RE: 1st radio ever, Philco 37-640 restoration - by morzh - 02-06-2014, 02:27 PM
Philco 91 Tuning Condenser
