A Philco 70/90 5-pin tube socket
It's the five pin socket, will work for 24/27/35/47 tube on your 70.
PM me your addr and I'll get it off to you.
A Philco 70/90 5-pin tube socket - by morzh - 02-05-2014, 12:58 PM
RE: A Philco 70/90 5-pin tube socket - by morzh - 02-05-2014, 10:19 PM
RE: A Philco 70/90 5-pin tube socket - by TV MAN - 02-06-2014, 10:43 AM
RE: A Philco 70/90 5-pin tube socket - by morzh - 02-06-2014, 10:47 AM
RE: A Philco 70/90 5-pin tube socket - by morzh - 02-06-2014, 11:07 AM
RE: A Philco 70/90 5-pin tube socket - by TA Forbes - 02-06-2014, 03:34 PM
RE: A Philco 70/90 5-pin tube socket - by morzh - 02-06-2014, 03:36 PM
Philco 91 Tuning Condenser
