Tale of a Z
The radio is an excellent performer, or I may not have bothered. Someone had been in and recapped a lot of it already (modern caps, doubt it was more than a few years ago), but apparently gave up when they couldn't get it to work. I found the problem right away, it was the RF choke in the power supply.
It is a pain to strip this chassis, but what the hey... new experience and all that. I just hope it turns out looking significantly better than it did.
Tale of a Z - by BrendaAnnD - 02-06-2014, 12:55 AM
RE: Tale of a Z - by OldRestorer - 02-06-2014, 08:49 AM
RE: Tale of a Z - by TA Forbes - 02-06-2014, 10:07 AM
RE: Tale of a Z - by BrendaAnnD - 02-06-2014, 10:26 AM
RE: Tale of a Z - by morzh - 02-06-2014, 10:38 AM
RE: Tale of a Z - by TA Forbes - 02-06-2014, 10:40 AM
RE: Tale of a Z - by morzh - 02-06-2014, 10:53 AM
RE: Tale of a Z - by exray - 02-06-2014, 11:53 AM
RE: Tale of a Z - by BrendaAnnD - 02-06-2014, 04:03 PM
RE: Tale of a Z - by morzh - 02-06-2014, 04:35 PM
RE: Tale of a Z - by BrendaAnnD - 02-06-2014, 09:03 PM
RE: Tale of a Z - by morzh - 02-06-2014, 09:08 PM
RE: Tale of a Z - by Arran - 02-07-2014, 12:14 AM
RE: Tale of a Z - by BrendaAnnD - 02-07-2014, 02:57 AM
RE: Tale of a Z - by Conelrad - 02-07-2014, 07:51 AM
RE: Tale of a Z - by keithw - 02-07-2014, 10:56 AM
RE: Tale of a Z - by morzh - 02-07-2014, 10:58 AM
RE: Tale of a Z - by BrendaAnnD - 02-07-2014, 01:19 PM
RE: Tale of a Z - by BrendaAnnD - 02-07-2014, 01:25 PM
RE: Tale of a Z - by hsusmann - 02-07-2014, 11:53 PM
RE: Tale of a Z - by Arran - 02-08-2014, 05:15 AM
RE: Tale of a Z - by BrendaAnnD - 02-08-2014, 05:45 AM
RE: Tale of a Z - by hsusmann - 02-08-2014, 08:45 AM
RE: Tale of a Z - by BrendaAnnD - 02-08-2014, 10:17 AM
RE: Tale of a Z - by BrendaAnnD - 02-09-2014, 04:05 AM
RE: Tale of a Z - by hsusmann - 02-09-2014, 09:13 AM
RE: Tale of a Z - by BrendaAnnD - 02-09-2014, 09:33 AM
RE: Tale of a Z - by hsusmann - 02-09-2014, 09:40 AM
RE: Tale of a Z - by morzh - 02-09-2014, 12:34 PM
RE: Tale of a Z - by wireless - 02-09-2014, 01:21 PM
RE: Tale of a Z - by Tom Hamilton - 02-11-2014, 01:51 PM
RE: Tale of a Z - by TA Forbes - 02-18-2014, 12:51 PM
RE: Tale of a Z - by BrendaAnnD - 02-20-2014, 09:14 AM
RE: Tale of a Z - by Tom Hamilton - 02-20-2014, 10:21 AM
RE: Tale of a Z - by morzh - 02-20-2014, 11:05 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7209 online users. [Complete List]
» 1 Member(s) | 7208 Guest(s)
