  • 1 Vote(s) - 5 Average
Philco 70 restoration attempt - singing now.
An example of a simplified electrolytic re-stuff.
The wires are not insulated - they are fairly rigid and will be held by being potted with hot glue.
The other side (where the capacitors serialize)
Potted
The wires coming out
I had to widen the hole in the base - the wires are fairly fat.
This is why I did not have to insulate the wires with heat shrink or tape - they are far enough apart and then the hot glue will get in between so it is secure.
RE: Philco 70 restoration attempt. - by morzh - 01-24-2014, 10:53 PM
RE: Philco 70 restoration attempt. - by morzh - 01-25-2014, 12:00 AM
RE: Philco 70 restoration attempt. - by morzh - 01-25-2014, 12:59 AM
RE: Philco 70 restoration attempt. - by Jamesm - 01-25-2014, 11:57 AM
RE: Philco 70 restoration attempt. - by gregb - 01-25-2014, 03:50 PM
RE: Philco 70 restoration attempt. - by morzh - 01-25-2014, 07:28 PM
RE: Philco 70 restoration attempt. - by morzh - 01-25-2014, 09:13 PM
RE: Philco 70 restoration attempt. - by Mondial - 01-26-2014, 12:28 AM
RE: Philco 70 restoration attempt. - by gregb - 01-26-2014, 12:40 AM
RE: Philco 70 restoration attempt. - by morzh - 01-26-2014, 02:57 PM
RE: Philco 70 restoration attempt. - by Raleigh - 01-27-2014, 02:12 PM
RE: Philco 70 restoration attempt. - by morzh - 01-27-2014, 02:46 PM
RE: Philco 70 restoration attempt. - by morzh - 01-31-2014, 10:10 PM
RE: Philco 70 restoration attempt. - by morzh - 01-31-2014, 10:11 PM
RE: Philco 70 restoration attempt. - by TV MAN - 02-01-2014, 01:20 PM
RE: Philco 70 restoration attempt. - by morzh - 02-01-2014, 01:53 PM
RE: Philco 70 restoration attempt. - by morzh - 02-01-2014, 11:27 PM
RE: Philco 70 restoration attempt. - by morzh - 02-01-2014, 11:39 PM
RE: Philco 70 restoration attempt. - by morzh - 02-02-2014, 09:12 PM
RE: Philco 70 restoration attempt. - by morzh - 02-02-2014, 09:25 PM
RE: Philco 70 restoration attempt. - by morzh - 02-03-2014, 09:32 PM
RE: Philco 70 restoration attempt. - by morzh - 02-05-2014, 01:04 PM
RE: Philco 70 restoration attempt. - by morzh - 02-06-2014, 09:03 PM
RE: Philco 70 restoration attempt. - by morzh - 02-07-2014, 04:52 PM
RE: Philco 70 restoration attempt. - by murf - 02-08-2014, 03:15 PM
RE: Philco 70 restoration attempt. - by morzh - 02-08-2014, 03:41 PM
RE: Philco 70 restoration attempt. - by TV MAN - 02-08-2014, 03:41 PM
RE: Philco 70 restoration attempt. - by morzh - 02-08-2014, 03:49 PM
RE: Philco 70 restoration attempt. - by morzh - 02-10-2014, 10:37 PM
RE: Philco 70 restoration attempt. - by TV MAN - 02-11-2014, 12:16 PM
RE: Philco 70 restoration attempt. - by morzh - 02-11-2014, 12:27 PM
RE: Philco 70 restoration attempt. - by morzh - 02-13-2014, 09:48 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6907 online users. [Complete List]
» 2 Member(s) | 6905 Guest(s)
