1st radio ever, Philco 37-640 restoration (DONE)
Chuck: Richtig, aber das Radio kein Spiel
Morzh: Was mal wieder? Ich spiele alle tag
Ok enough of that, lol. I'm only getting a little of most of this and translating the rest, Icon_mrgreen
RE: 1st radio ever, Philco 37-640 restoration - by OldRestorer - 02-06-2014, 11:25 PM
Philco 91 Tuning Condenser
