Philco 46-1203
Thanks to this cold weather I am finally able to spend some time on the radio. The first thing I replace was the power cord. Major safety issue. Working in section 1 (Power input) the first thing I noticed was that the way in which components are wired do not match the schematics. I checked the production changes and still they do not match. While I can tune in a radio station there is a loud hum so I'm going to simply replace each capacitor one at a time while leaving the radio wired as it currently is. Any other advice is greatly appreciated.
Philco 46-1203 - by Colorado Jeff - 10-18-2013, 12:11 PM
RE: Philco 46-1203 - by klondike98 - 10-18-2013, 05:07 PM
RE: Philco 46-1203 - by Colorado Jeff - 10-18-2013, 07:28 PM
RE: Philco 46-1203 - by klondike98 - 10-18-2013, 08:35 PM
RE: Philco 46-1203 - by Colorado Jeff - 10-30-2013, 09:53 AM
RE: Philco 46-1203 - by Colorado Jeff - 10-30-2013, 10:44 AM
RE: Philco 46-1203 - by klondike98 - 10-30-2013, 11:03 AM
RE: Philco 46-1203 - by klondike98 - 10-30-2013, 11:06 AM
RE: Philco 46-1203 - by Colorado Jeff - 10-30-2013, 12:30 PM
RE: Philco 46-1203 - by codefox1 - 10-30-2013, 03:00 PM
RE: Philco 46-1203 - by klondike98 - 10-30-2013, 06:49 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-07-2014, 01:13 PM
RE: Philco 46-1203 - by morzh - 02-07-2014, 02:31 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-07-2014, 02:38 PM
RE: Philco 46-1203 - by skyscraper - 02-07-2014, 03:00 PM
RE: Philco 46-1203 - by morzh - 02-07-2014, 03:00 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-07-2014, 04:21 PM
RE: Philco 46-1203 - by morzh - 02-07-2014, 04:27 PM
RE: Philco 46-1203 - by Colorado Jeff - 02-08-2014, 11:19 PM
RE: Philco 46-1203 - by wa2ise - 02-09-2014, 01:09 AM
Philco 91 Tuning Condenser
There are currently 4700 online users. [Complete List]
» 2 Member(s) | 4698 Guest(s)
