  • 1 Vote(s) - 5 Average
Philco 45 Butterfly Restoration Chronicles....Finished
#48
Kirk, you brought those radios back from the dead before, and you'll do it again with even better results this time. Sometimes, after something like this happens, you just need to walk away and take a break for a while.
RE: Philco 45 Butterfly Restoration Chronicles....Finished - by Eliot Ness - 02-09-2014, 02:02 PM
