Model 20A philco very poor grille, restore or replace?
I have a model 20 deluxe with the maple pieces along the top that has the same damaged grill issue. Just picked it up for 25 bucks with a light bulb shaped philco 80 tube and all light bulb shaped 24's still intact. I thought there was a guy on Ebay selling pre-cut model 20 fronts. Can't find him now? Thanks for the posts here as I was just getting ready to inquire about the same thing.
RE: Model 20A philco very poor grille, restore or replace? - by dfields69 - 02-09-2014, 02:31 PM
Philco 91 Tuning Condenser
There are currently 6876 online users. [Complete List]
» 2 Member(s) | 6874 Guest(s)
