Alignment Questions
There should be a 3 or 4 lug terminal strip usually on the left back of the chassis. I align using an analog ohm meter connected to the speaker leads. Align BC at 455 on your signal gen with tuning plates closed, your directions should tell you the high end settings, usually somewhere around 1500. Are you getting sound with the sig gen hooked up? Should be a steady tone.
Alignment Questions - by Warren - 02-10-2014, 12:08 AM
RE: Alignment Questions - by tab10672 - 02-10-2014, 12:58 AM
RE: Alignment Questions - by Warren - 02-10-2014, 01:29 AM
RE: Alignment Questions - by Raleigh - 02-10-2014, 01:48 AM
RE: Alignment Questions - by Raleigh - 02-10-2014, 02:00 AM
RE: Alignment Questions - by Warren - 02-10-2014, 02:01 AM
RE: Alignment Questions - by Raleigh - 02-10-2014, 02:13 AM
RE: Alignment Questions - by Warren - 02-10-2014, 02:57 AM
RE: Alignment Questions - by tab10672 - 02-10-2014, 09:43 AM
RE: Alignment Questions - by tab10672 - 02-10-2014, 09:46 AM
RE: Alignment Questions - by Raleigh - 02-10-2014, 01:17 PM
RE: Alignment Questions - by Warren - 02-10-2014, 02:51 PM
RE: Alignment Questions - by Warren - 02-11-2014, 06:03 PM
RE: Alignment Questions - by Warren - 02-12-2014, 04:38 PM
RE: Alignment Questions - by tab10672 - 02-12-2014, 08:00 PM
RE: Alignment Questions - by Warren - 02-12-2014, 11:39 PM
RE: Alignment Questions - by tab10672 - 02-13-2014, 03:15 PM
RE: Alignment Questions - by jerryhawthorne - 02-13-2014, 03:48 PM
RE: Alignment Questions - by Warren - 02-13-2014, 04:34 PM
RE: Alignment Questions - by Warren - 02-14-2014, 12:51 AM
RE: Alignment Questions - by tab10672 - 02-14-2014, 01:29 AM
RE: Alignment Questions - by Warren - 02-14-2014, 01:59 AM
RE: Alignment Questions - by tab10672 - 02-14-2014, 02:07 AM
RE: Alignment Questions - by tab10672 - 02-14-2014, 02:13 AM
RE: Alignment Questions - by Warren - 02-14-2014, 03:12 AM
RE: Alignment Questions - by tab10672 - 02-14-2014, 01:48 PM
RE: Alignment Questions - by Raleigh - 02-14-2014, 02:45 PM
RE: Alignment Questions - by Warren - 02-14-2014, 04:24 PM
RE: Alignment Questions - by Raleigh - 02-14-2014, 06:07 PM
There are currently 7608 online users. [Complete List]
» 1 Member(s) | 7607 Guest(s)
