Help with Cleaning Dials
OK, Message recieved! Glad I asked the question.
I won't use anything to clean the dial. Thanks for the quick reply, I was getting antsy to do just that.
I knew I could count on you guys for help! Now, if I could just generate capacitors out of thin air.......and wave my hand and have them all soldered in.........*Poof*....Were you saying something??....
Thanks again.
John
Help with Cleaning Dials - by phly guy - 06-24-2008, 11:53 AM
[No subject] - by Chuck Schwark - 06-24-2008, 01:12 PM
[No subject] - by PhilcoPhil - 06-24-2008, 06:09 PM
[No subject] - by phly guy - 06-24-2008, 10:47 PM
[No subject] - by BDM - 06-24-2008, 11:58 PM
There are currently 8084 online users. [Complete List]
» 5 Member(s) | 8079 Guest(s)
AvatarAvatarAvatarAvatar
