What wire guage to use for rewire?
18 gauge should be fine. But, why not just remove the crumbling insulation and slide on a piece of heat shrink? That's what I do. Far easier in my book, plus you keep the lengths proper. Which may avoid unwanted oscillation and/or noise.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
What wire guage to use for rewire? - by phly guy - 06-24-2008, 11:56 AM
[No subject] - by BDM - 06-25-2008, 12:01 AM
[No subject] - by Texasrocker - 06-25-2008, 03:16 AM
[No subject] - by rghines1 - 06-25-2008, 10:18 AM
[No subject] - by phly guy - 06-25-2008, 02:04 PM
[No subject] - by Texasrocker - 06-27-2008, 12:57 AM
[No subject] - by exray - 06-27-2008, 01:14 AM
[No subject] - by phly guy - 06-27-2008, 11:53 AM
[No subject] - by Texasrocker - 06-29-2008, 02:09 AM
[No subject] - by Ron Ramirez - 07-03-2008, 10:38 AM
There are currently 10425 online users. [Complete List]
» 2 Member(s) | 10423 Guest(s)
