Two Philcos
20 is not bad, just gutting that large metal capacitor can is a b...ch. Otherwise a straightforward and very simple set.
Two Philcos - by Section10 - 02-10-2014, 05:31 PM
RE: Two Philcos - by tab10672 - 02-10-2014, 10:34 PM
RE: Two Philcos - by morzh - 02-10-2014, 10:59 PM
RE: Two Philcos - by klondike98 - 02-10-2014, 11:17 PM
RE: Two Philcos - by GarySP - 02-11-2014, 01:28 PM
RE: Two Philcos - by morzh - 02-11-2014, 02:24 PM
RE: Two Philcos - by SteveJB - 02-11-2014, 04:25 PM
RE: Two Philcos - by 37silverstreak - 02-11-2014, 08:40 PM
RE: Two Philcos - by Radioroslyn - 02-13-2014, 06:06 PM
RE: Two Philcos - by GarySP - 02-14-2014, 06:14 PM
RE: Two Philcos - by morzh - 02-14-2014, 06:22 PM
RE: Two Philcos - by Section10 - 02-16-2014, 08:53 AM
RE: Two Philcos - by Mondial - 02-16-2014, 12:36 PM
RE: Two Philcos - by Section10 - 02-16-2014, 02:37 PM
RE: Two Philcos - by PhilcoJohn - 02-16-2014, 04:33 PM
Philco 91 Tuning Condenser
There are currently 9432 online users. [Complete List]
» 1 Member(s) | 9431 Guest(s)
