Philco model 70 rebuild - by Tim P.
Threads: 83
City: Annapolis, IL
State, Province, Country: USA
Here are some shots of the progress. My electrolytics are the Sprague brand. I had thought about filing the top a little and overlapping.
Tim
RE: Philco model 70 rebuild - by Tim P. - by TV MAN - 02-11-2014, 12:43 PM
Users browsing this thread: 14 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
