4 Radio cabinets finished in one day!
NICE JOB! Wish I had that expertism to do that ... LOL!
RE: 4 Radio cabinets finished in one day! - by PhilcoJohn - 02-11-2014, 07:38 PM
Philco 91 Tuning Condenser
There are currently 8322 online users. [Complete List]
» 2 Member(s) | 8320 Guest(s)
