  • 1 Vote(s) - 4 Average
Question about the Zenith 8s-154
Thanks guys ... I picked up for $125.00... It will be put on the back burner, could not pass it up the cabinet is in very good condition. The wife says NO MORE CONSOLE RADIOS OR ELSE! We will see about that.....
Question about the Zenith 8s-154 - by PhilcoJohn - 02-06-2014, 03:19 PM
RE: Question about the Zenith 8s-154 - by morzh - 02-06-2014, 03:34 PM
RE: Question about the Zenith 8s-154 - by morzh - 02-06-2014, 04:34 PM
RE: Question about the Zenith 8s-154 - by PhilcoJohn - 02-11-2014, 07:41 PM
RE: Question about the Zenith 8s-154 - by morzh - 02-11-2014, 09:48 PM
RE: Question about the Zenith 8s-154 - by Arran - 02-12-2014, 01:23 AM
RE: Question about the Zenith 8s-154 - by morzh - 02-12-2014, 11:10 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
