Model 77 questions
Thank you for the quick replies! After reading up on the bakelite caps, I am going ahead and rebuilding them. This should be fun! I will tell my cabinet guy about the walnut veneer, that was a big help, as one side is still intact. (top and side damaged). I have another question: there are 3 flat metal containers screwed to the under side of the chassis, two cover up the IF stages, and one covers up the output stage. The two on the IF stage appear to have two wires coming out of one end, and the one at the OP seems to have only one wire. What the heck are these? Do they need attention as well? thank you in advance, Dan
Model 77 questions - by Guest - 06-24-2008, 11:07 AM
[No subject] - by philco phan - 06-24-2008, 06:09 PM
[No subject] - by Ron Ramirez - 06-24-2008, 09:27 PM
[No subject] - by Guest - 06-25-2008, 09:40 AM
[No subject] - by Ron Ramirez - 06-25-2008, 05:52 PM
[No subject] - by Guest - 06-26-2008, 12:32 AM
[No subject] - by wonderwrench - 06-26-2008, 12:49 AM
Ok, I found a little info on the other forum, these ICs are 'clocking' ics, and are my horizontal drive. So, now, I need...TV MAN — 02:03 PM
Well, here's a head scratcher. I had been using my 1077 while working on the Emerson and the last time I tried to use it...TV MAN — 01:26 PM
Indeed. Thank you all. I'll remove and test the rest of the transistors. I'm trying to trace everything at the test p...R3Sons — 12:06 PM
Yes, if the speaker was disconnected or bad connections, it could cause high enough voltage spikes on the collector to k...462ron — 10:40 AM
42-345 Resistors
Good.morzh — 10:38 AM
I would check things around before simply replacing the transistor. Something killef it.morzh — 10:37 AM
÷1 to Sincere Richard. I use Mouser but either is the way to go. I'm sure the others, like justradios, are in the group...RodB — 10:24 AM
RS3, that output transistor X6…AR14, can be replaced with a GE-3 or ECG-121, probably others too. Ron462ron — 10:01 AM
Philco 7053
Thread moved to test equipment section. (I have not used one of these)klondike98 — 07:05 AM
Thank you Richard.R3Sons — 01:37 AM
There are currently 2684 online users. [Complete List]
» 2 Member(s) | 2682 Guest(s)
