Model 77 questions
Those are condensers as well, and yes, they also need to be replaced with new.
You can put new capacitors inside those old cans, as well.
Model 77 is a TRF set - it has no IF stages, only RF.
Model 77 questions - by Guest - 06-24-2008, 11:07 AM
[No subject] - by philco phan - 06-24-2008, 06:09 PM
[No subject] - by Ron Ramirez - 06-24-2008, 09:27 PM
[No subject] - by Guest - 06-25-2008, 09:40 AM
[No subject] - by Ron Ramirez - 06-25-2008, 05:52 PM
[No subject] - by Guest - 06-26-2008, 12:32 AM
[No subject] - by wonderwrench - 06-26-2008, 12:49 AM
Ok, I found a little info on the other forum, these ICs are 'clocking' ics, and are my horizontal drive. So, now, I need...TV MAN — 02:03 PM
Well, here's a head scratcher. I had been using my 1077 while working on the Emerson and the last time I tried to use it...TV MAN — 01:26 PM
Indeed. Thank you all. I'll remove and test the rest of the transistors. I'm trying to trace everything at the test p...R3Sons — 12:06 PM
Yes, if the speaker was disconnected or bad connections, it could cause high enough voltage spikes on the collector to k...462ron — 10:40 AM
42-345 Resistors
Good.morzh — 10:38 AM
I would check things around before simply replacing the transistor. Something killef it.morzh — 10:37 AM
÷1 to Sincere Richard. I use Mouser but either is the way to go. I'm sure the others, like justradios, are in the group...RodB — 10:24 AM
RS3, that output transistor X6…AR14, can be replaced with a GE-3 or ECG-121, probably others too. Ron462ron — 10:01 AM
Philco 7053
Thread moved to test equipment section. (I have not used one of these)klondike98 — 07:05 AM
Thank you Richard.R3Sons — 01:37 AM
There are currently 1295 online users. [Complete List]
» 2 Member(s) | 1293 Guest(s)
