Model 77 questions
Ok well, that explains the unusual schematic. Duh! I guess I need to brush up on my theory! Btw, is there a link as to what to do with these condensors? I don't want to ruin them in an attempt to fix them! Years ago when I was in my teens I was "restoring" old radios, but its been about 25 years since I've done this stuff. (I'm an electronic accessory tech in the auto industry now.) I have done some work with the "newer" old stuff recently; I've reconditioned and aligned a Dynaco FM 3, Pas 3, and ST70. And I've scratch built a single ended stereo amp using a 5U4, 12AX7, and 2 6BQ5's. But, I do not recall anything as peculiar and interesting as this '77! I would like to thank you again for all the help so far and will keep you informed of the progress on this project.
Cheers! Dan
Model 77 questions - by Guest - 06-24-2008, 11:07 AM
[No subject] - by philco phan - 06-24-2008, 06:09 PM
[No subject] - by Ron Ramirez - 06-24-2008, 09:27 PM
[No subject] - by Guest - 06-25-2008, 09:40 AM
[No subject] - by Ron Ramirez - 06-25-2008, 05:52 PM
[No subject] - by Guest - 06-26-2008, 12:32 AM
[No subject] - by wonderwrench - 06-26-2008, 12:49 AM
Ok, I found a little info on the other forum, these ICs are 'clocking' ics, and are my horizontal drive. So, now, I need...TV MAN — 02:03 PM
Well, here's a head scratcher. I had been using my 1077 while working on the Emerson and the last time I tried to use it...TV MAN — 01:26 PM
Indeed. Thank you all. I'll remove and test the rest of the transistors. I'm trying to trace everything at the test p...R3Sons — 12:06 PM
Yes, if the speaker was disconnected or bad connections, it could cause high enough voltage spikes on the collector to k...462ron — 10:40 AM
42-345 Resistors
Good.morzh — 10:38 AM
I would check things around before simply replacing the transistor. Something killef it.morzh — 10:37 AM
÷1 to Sincere Richard. I use Mouser but either is the way to go. I'm sure the others, like justradios, are in the group...RodB — 10:24 AM
RS3, that output transistor X6…AR14, can be replaced with a GE-3 or ECG-121, probably others too. Ron462ron — 10:01 AM
Philco 7053
Thread moved to test equipment section. (I have not used one of these)klondike98 — 07:05 AM
Thank you Richard.R3Sons — 01:37 AM
