philco 84 and 84B whats the difference?
oldrestorer Wrote:so they use the same schematic?
Well...sort of...you need to see what changes were made over the years the 84B was produced.
See: http://www.philcoradio.com/phorum/showth...hp?tid=215 or you can order the info from Chuck @ http://www.philcorepairbench.com/schematics.htm
RE: philco 84 and 84B whats the difference? - by klondike98 - 02-12-2014, 09:38 PM
There are currently 9083 online users. [Complete List]
» 2 Member(s) | 9081 Guest(s)
