Broken on/off switch
An article of interest involving the power switch on another 1942 Philco:
http://www.philcoradio.com/notebook/41226.htm
Broken on/off switch - by Diverted - 02-12-2014, 08:57 PM
RE: Broken on/off switch - by murf - 02-12-2014, 09:36 PM
RE: Broken on/off switch - by Arran - 02-12-2014, 09:44 PM
RE: Broken on/off switch - by morzh - 02-12-2014, 10:26 PM
RE: Broken on/off switch - by Diverted - 02-12-2014, 11:23 PM
RE: Broken on/off switch - by Warren - 02-12-2014, 11:43 PM
RE: Broken on/off switch - by BrendaAnnD - 02-13-2014, 02:02 AM
RE: Broken on/off switch - by Eric T - 02-13-2014, 08:24 AM
RE: Broken on/off switch - by Ron Ramirez - 02-13-2014, 12:26 PM
RE: Broken on/off switch - by morzh - 02-13-2014, 12:41 PM
RE: Broken on/off switch - by Warren - 02-13-2014, 01:59 PM
RE: Broken on/off switch - by Chuck Schwark - 02-13-2014, 02:04 PM
RE: Broken on/off switch - by Diverted - 02-13-2014, 02:21 PM
RE: Broken on/off switch - by Diverted - 02-14-2014, 04:50 PM
RE: Broken on/off switch - by morzh - 02-14-2014, 05:22 PM
There are currently 9958 online users. [Complete List]
» 2 Member(s) | 9956 Guest(s)
