37-604 Filter Choke Question (part 59)
Got me, but interesting find non the less.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
[No subject] - by davemc - 06-19-2008, 05:16 PM
[No subject] - by davemc - 06-26-2008, 07:17 AM
[No subject] - by davemc - 06-26-2008, 07:18 AM
[No subject] - by BDM - 06-26-2008, 01:04 PM
[No subject] - by Texasrocker - 06-27-2008, 01:23 AM
[No subject] - by exray - 06-27-2008, 01:40 AM
[No subject] - by Ron Ramirez - 07-03-2008, 10:51 AM
There are currently 4579 online users. [Complete List]
» 3 Member(s) | 4576 Guest(s)
