  • 1 Vote(s) - 5 Average
Model 70 pm speaker
Actually transformer form 20, 2766, could be used as an output transformer for 70, as it is a universal PP/SE transformer, in the latter case the centertap is not used, when it is used for 1x47 output. So the 20 speaker is fully good for 70 except you have to re-wire the way the transformer is connected
Model 70 pm speaker - by tab10672 - 02-11-2014, 06:47 PM
RE: Model 70 pm speaker - by morzh - 02-11-2014, 09:40 PM
RE: Model 70 pm speaker - by TV MAN - 02-13-2014, 06:30 PM
RE: Model 70 pm speaker - by tab10672 - 02-13-2014, 06:46 PM
RE: Model 70 pm speaker - by morzh - 02-13-2014, 06:52 PM
RE: Model 70 pm speaker - by TV MAN - 02-13-2014, 08:44 PM
RE: Model 70 pm speaker - by morzh - 02-13-2014, 09:36 PM
Philco 91 Tuning Condenser
