  • 1 Vote(s) - 5 Average
Model 70 pm speaker
I looked up the 47 tube and the specs showed 7000 load ohms, so the 20 transformer was within range. So, like morzh mentioned, this should work. Clip and insulate the center tap wire, use the outside wires and see what you have.
Tim
Model 70 pm speaker - by tab10672 - 02-11-2014, 06:47 PM
RE: Model 70 pm speaker - by morzh - 02-11-2014, 09:40 PM
RE: Model 70 pm speaker - by TV MAN - 02-13-2014, 06:30 PM
RE: Model 70 pm speaker - by tab10672 - 02-13-2014, 06:46 PM
RE: Model 70 pm speaker - by morzh - 02-13-2014, 06:52 PM
RE: Model 70 pm speaker - by TV MAN - 02-13-2014, 08:44 PM
RE: Model 70 pm speaker - by morzh - 02-13-2014, 09:36 PM
Philco 91 Tuning Condenser
There are currently 7133 online users. [Complete List]
» 2 Member(s) | 7131 Guest(s)
