  • 1 Vote(s) - 5 Average
Model 70 pm speaker
I would not even clip teh wire - what if one day you get the real thing and decide to use the 20 for some 20 you at the time will be working on.
Just roll it up tight and wrap in insulating tape.
BTW the 2766 transformer is shown as both PP and SE for 47 tube in Chuck's transformer table on the Philco Repair Bench website.
Model 70 pm speaker - by tab10672 - 02-11-2014, 06:47 PM
RE: Model 70 pm speaker - by morzh - 02-11-2014, 09:40 PM
RE: Model 70 pm speaker - by TV MAN - 02-13-2014, 06:30 PM
RE: Model 70 pm speaker - by tab10672 - 02-13-2014, 06:46 PM
RE: Model 70 pm speaker - by morzh - 02-13-2014, 06:52 PM
RE: Model 70 pm speaker - by TV MAN - 02-13-2014, 08:44 PM
RE: Model 70 pm speaker - by morzh - 02-13-2014, 09:36 PM
Philco 91 Tuning Condenser
There are currently 10418 online users. [Complete List]
» 2 Member(s) | 10416 Guest(s)
