what type of walnut is this?
This looks closer than anything else I have bought so it will have to do.
http://www.ebay.com/itm/151228333073
what type of walnut is this? - by tab10672 - 02-13-2014, 08:24 PM
RE: what type of walnut is this? - by OldRestorer - 02-13-2014, 09:07 PM
RE: what type of walnut is this? - by tab10672 - 02-14-2014, 12:26 AM
RE: what type of walnut is this? - by Steve Davis - 02-14-2014, 11:13 AM
RE: what type of walnut is this? - by tab10672 - 02-14-2014, 01:53 PM
RE: what type of walnut is this? - by tab10672 - 02-14-2014, 02:01 PM
RE: what type of walnut is this? - by Steve Davis - 02-14-2014, 02:23 PM
RE: what type of walnut is this? - by tab10672 - 02-14-2014, 02:37 PM
RE: what type of walnut is this? - by Steve Davis - 02-17-2014, 02:33 PM
RE: what type of walnut is this? - by OldRestorer - 02-17-2014, 07:25 PM
RE: what type of walnut is this? - by Warren - 02-18-2014, 12:46 AM
RE: what type of walnut is this? - by gregb - 02-18-2014, 10:59 AM
Philco 91 Tuning Condenser
There are currently 10177 online users. [Complete List]
» 2 Member(s) | 10175 Guest(s)
