Alignment Questions
Ok, I will try that, seems strange. Should I get a tone also through the speaker at the same time? Also, should the am antenna be hooked up also? Thanks for your time on this.
Alignment Questions - by Warren - 02-10-2014, 12:08 AM
RE: Alignment Questions - by tab10672 - 02-10-2014, 12:58 AM
RE: Alignment Questions - by Warren - 02-10-2014, 01:29 AM
RE: Alignment Questions - by Raleigh - 02-10-2014, 01:48 AM
RE: Alignment Questions - by Raleigh - 02-10-2014, 02:00 AM
RE: Alignment Questions - by Warren - 02-10-2014, 02:01 AM
RE: Alignment Questions - by Raleigh - 02-10-2014, 02:13 AM
RE: Alignment Questions - by Warren - 02-10-2014, 02:57 AM
RE: Alignment Questions - by tab10672 - 02-10-2014, 09:43 AM
RE: Alignment Questions - by tab10672 - 02-10-2014, 09:46 AM
RE: Alignment Questions - by Raleigh - 02-10-2014, 01:17 PM
RE: Alignment Questions - by Warren - 02-10-2014, 02:51 PM
RE: Alignment Questions - by Warren - 02-11-2014, 06:03 PM
RE: Alignment Questions - by Warren - 02-12-2014, 04:38 PM
RE: Alignment Questions - by tab10672 - 02-12-2014, 08:00 PM
RE: Alignment Questions - by Warren - 02-12-2014, 11:39 PM
RE: Alignment Questions - by tab10672 - 02-13-2014, 03:15 PM
RE: Alignment Questions - by jerryhawthorne - 02-13-2014, 03:48 PM
RE: Alignment Questions - by Warren - 02-13-2014, 04:34 PM
RE: Alignment Questions - by Warren - 02-14-2014, 12:51 AM
RE: Alignment Questions - by tab10672 - 02-14-2014, 01:29 AM
RE: Alignment Questions - by Warren - 02-14-2014, 01:59 AM
RE: Alignment Questions - by tab10672 - 02-14-2014, 02:07 AM
RE: Alignment Questions - by tab10672 - 02-14-2014, 02:13 AM
RE: Alignment Questions - by Warren - 02-14-2014, 03:12 AM
RE: Alignment Questions - by tab10672 - 02-14-2014, 01:48 PM
RE: Alignment Questions - by Raleigh - 02-14-2014, 02:45 PM
RE: Alignment Questions - by Warren - 02-14-2014, 04:24 PM
RE: Alignment Questions - by Raleigh - 02-14-2014, 06:07 PM
Philco 91 Tuning Condenser
