A tuning cap question
If the mechanics of the dial mechanism are such that the var cap over-travels, then I would insulate that alum bridge plate. Couple layers of electrical tape cut to match the bridge's rectangular shape.
Chuck
A tuning cap question - by morzh - 02-14-2014, 03:35 PM
RE: A tuning cap question - by Chuck Schwark - 02-14-2014, 03:54 PM
RE: A tuning cap question - by morzh - 02-14-2014, 03:54 PM
RE: A tuning cap question - by morzh - 02-14-2014, 03:57 PM
RE: A tuning cap question - by Chuck Schwark - 02-14-2014, 05:23 PM
RE: A tuning cap question - by morzh - 02-14-2014, 05:37 PM
RE: A tuning cap question - by Chuck Schwark - 02-14-2014, 05:45 PM
RE: A tuning cap question - by morzh - 02-14-2014, 05:48 PM
Philco 91 Tuning Condenser
