A tuning cap question
Yes that is where I thought of Kapton above....I have a roll at work.
But the mechanics of the dial when aligned propely, as I found out, keep the cap from over-travelling. So it is OK now even without the Kapton. I just never saw the cap by itself touching before. Even with aluminum bar bridges.....maybe I did not really tried. Icon_smile
thanks Chuck.
A tuning cap question - by morzh - 02-14-2014, 03:35 PM
RE: A tuning cap question - by Chuck Schwark - 02-14-2014, 03:54 PM
RE: A tuning cap question - by morzh - 02-14-2014, 03:54 PM
RE: A tuning cap question - by morzh - 02-14-2014, 03:57 PM
RE: A tuning cap question - by Chuck Schwark - 02-14-2014, 05:23 PM
RE: A tuning cap question - by morzh - 02-14-2014, 05:37 PM
RE: A tuning cap question - by Chuck Schwark - 02-14-2014, 05:45 PM
RE: A tuning cap question - by morzh - 02-14-2014, 05:48 PM
Philco 91 Tuning Condenser
